tis-java8 / FEHLERstatus
Antwort
Aramis
Nachrichten: 17
Anmeldung: 16. Juli 2024 - 11:48 Uhr
1. August 2024 – 14:24 Uhr
Ich verwende WAPT Enterprise Version 2.5.5.15691 auf einem Debian 12.6 Server (6.1.94-1 (2024-06-21)).
Ich habe versucht, das tis-java8-Paket über eine AD-Organisationseinheit auf den Workstations zu verteilen.
Ich erhalte folgende Fehlermeldung:
Installing: drsilil-java8
WARNING: A Java Runtime Environment 8 (JRE) will be installed with WAPT since this package allow arbitrary install based on available package in a specific order
Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
  File "<string>", line 1939, in run
    self._run()
Exception: Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
    self._run()
Ich glaube also, dass dies nicht die richtige angepasste Version ist.
Ich entferne das Paket aus der Liste der Pakete, die in dieser Organisationseinheit installiert werden sollen.
Bei jeder Maschine trat wiederholt ein Fehler im Status auf.
Ich habe also das Paket wapt-forget-packages ausprobiert, indem ich das Paket tis-java8 korrekt angegeben habe, aber leider ohne Erfolg, da dieses Paket letztendlich nicht auf den Rechnern installiert ist.
Der Fehler wird weiterhin in der Konsole mit einem Fehlerstatus für jede Maschine angezeigt.
Nach Durchsicht des Forums wird empfohlen, den Befehl „Paket vergessen“ zu verwenden.
Dieser Befehl ist jedoch nicht verfügbar, wenn ich einen Rechner auswähle.
Wie kann ich den Status jeder einzelnen Maschine wiederherstellen und die Installation dieses Pakets endgültig entfernen?
Vielen Dank für jeden Ratschlag, den Sie mir geben können.
Aufrichtig,
Nachrichten: 2376
14. August 2024 – 13:25 Uhr
Das Paket tis-java8 ist recht spezifisch.
Es versucht, eines der folgenden Pakete zu installieren:
tis-adoptium-openjdk8-jre,
tis-oracle-java8-jre-free
oder tis-oracle-java8-jre-nonfree.
Daher muss Ihr Repository mindestens eines dieser drei Pakete enthalten.
Je nach Ihren Java-Anforderungen können Sie selbst entscheiden, welches Paket Sie benötigen.
Antwort
