Seite 1 von 1
KB5000802 BSOD-Fehler – Druckerproblem beheben
Veröffentlicht: 15. März 2021 - 10:59 Uhr
von nliaudat
wapt-Paket zur Behebung des in KB5000802 eingeführten Druckerfehlers:
#https://www.windowslatest.com/2021/03/1 ... ch-update/
##https://www.windowslatest.com/2021/03/13/microsoft-working-on-a-fix-for-windows-10-bsod-march-update/
import ctypes
from ctypes.wintypes import BYTE, DWORD, LPCWSTR
printers = [
    'KX DRIVER for Universal Printing',
    'TASKalfa 4052ci',
    'Kyocera TASKalfa 4052ci KX',
    'Kyocera TASKalfa 3252ci KX',
    'Kyocera TASKalfa 3252ci'
    pass
    winspool = ctypes.WinDLL('winspool.drv')  # for EnumPrintersW
    msvcrt = ctypes.cdll.msvcrt  # for malloc, free
    # Parameters: modify as you need. See MSDN for detail.
    PRINTER_ENUM_LOCAL = 2
    Name = None  # ignored for PRINTER_ENUM_LOCAL
    Level = 1  # or 2, 4, 5
    class PRINTER_INFO_1(ctypes.Structure):
        _fields_ = [
            ("Flags", DWORD),
            ("pDescription", LPCWSTR),
            ("pName", LPCWSTR),
            ("pComment", LPCWSTR),
    # Invoke once with a NULL pointer to get buffer size.
    info = ctypes.POINTER(BYTE)()
    pcbNeeded = DWORD(0)
    pcReturned = DWORD(0)  # the number of PRINTER_INFO_1 structures retrieved
    winspool.EnumPrintersW(PRINTER_ENUM_LOCAL, Name, Level, ctypes.byref(info), 0,
            ctypes.byref(pcbNeeded), ctypes.byref(pcReturned))
    bufsize = pcbNeeded.value
    buffer = msvcrt.malloc(bufsize)
    winspool.EnumPrintersW(PRINTER_ENUM_LOCAL, Name, Level, buffer, bufsize,
    info = ctypes.cast(buffer, ctypes.POINTER(PRINTER_INFO_1))
    for i in range(pcReturned.value):
        print info[i].pName, '=>', info[i].pDescription
        if info[i].pName in printers:
        #print('Enable direct print for kyocera')
        #for printer in printers:
            print('    Fix %s' % info[i].pName)
            run_notfatal(r'rundll32 printui.dll,PrintUIEntry /Xs /n "%s" attributes +direct' % info[i].pName)
    msvcrt.free(buffer)
    pass
    # put here what to do when package is removed from host
    # implicit context variables are WAPT, control, user, params, run
        _fields_ = [
            ("Flags", DWORD),
            ("pName", LPCWSTR),
            run_notfatal(r'rundll32 printui.dll,PrintUIEntry /Xs /n "%s" attributes -direct' % info[i].pName)
    msvcrt.free(buffer)
Betreff: KB5000802 BSOD-Fehler – Druckerproblem beheben
Veröffentlicht: 16. März 2021 - 10:06 Uhr
von nliaudat
Update nach MS-Fix:
print('Install kb5001567')
    #2359302 = WU_S_ALREADY_INSTALLED
    run('wusa.exe windows10.0-kb5001567-x64_e3c7e1cb6fa3857b5b0c8cf487e7e16213b1ea83.msu /quiet /norestart',accept_returncodes=[0,2359302])
def audit():
    print(run_notfatal(r'wmic qfe list | findstr 5001567'))
    return "OK"
