Seite 1 von 1
Stormshield SSL VPN-Paket
Veröffentlicht: 21. September 2023 - 11:39 Uhr
von SeiyaGame
Ich möchte meinen Code für die Stormshield SSL VPN-Software anbieten; ich habe ihn auf den verschiedenen Beiträgen zu diesem Thema basiert ( 3515, 3628 )
Hinsichtlich der Installation habe ich nur ein paar kleinere Änderungen vorgenommen:
from setupdevhelpers import *
FIREWALL_IP_ADDRESS = "YOUR_IP_ADDRESS_OR_DNS"
stormshield_folder = makepath(programfiles64, 'Stormshield\Stormshield SSL VPN Client')
    # Declaring local variables
    bin_name = glob.glob("Stormshield*.msi")[0]
    # Installing the software
    print(f"Installing: {bin_name}")
    install_msi_if_needed(
        bin_name,
        min_version=control.get_software_version()
    create_programs_menu_shortcut("Stormshield SSL VPN Client", target=makepath(stormshield_folder, 'sslvpn_client.exe'), folder='Stormshield SSL VPN Client')
def session_setup():
    CURRENT_USER = os.getlogin()
    # Setup Firewall address
    registry_set(HKEY_CURRENT_USER, r"Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT", "address", FIREWALL_IP_ADDRESS, type=REG_SZ)
    registry_set(HKEY_CURRENT_USER, r'Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT', 'automatic', 'true', type=REG_SZ)
    registry_set(HKEY_CURRENT_USER, r'Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT', 'username', CURRENT_USER, type=REG_SZ)
    # Needed ?
    #mkdirs(makepath(user_local_appdata, 'Stormshield\Stormshield SSL VPN Client\config'))
    #run(makepath(stormshield_folder, 'scripts\generate_ovpn_auth.bat'))
    remove_programs_menu_folder('Stormshield SSL VPN Client')
def audit():
    service_name = "Stormshield SSL VPN Service"
    service_start_mode = get_service_start_mode(service_name)
    service_status = service_is_running(service_name)
    if service_start_mode in ["Disabled", "Manual"] and service_status:
        print(f"The {service_name} is stopped and prevents the application from working properly.")
        return "ERROR"
        print(f"The {service_name} service is working properly.")
        return "OK"
Ich habe auch das Update-Paket erstellt; es gibt möglicherweise noch einige Verbesserungsmöglichkeiten:
import re
# Constantes
BASE_URL = "https://vpn.stormshield.eu/"
DOWNLOAD_FILE_PATTERN = "_win10_fr_x64.msi"
def update_package():
    package_updated = False
    proxies = get_proxies() or get_proxies_from_wapt_console()
    app_name = control.name
    # Getting latest download link from official sources
    url_version = BASE_URL + "js/app.js"
    print(f"URL utilisée : {url_version}")
    app_js = wgets(url_version, proxies=proxies).decode('utf-8')
    pattern = r"const\s+pathVersionSSLVPN\s*=\s*(.*);"
    match = re.search(pattern, app_js)
    if match:
        path_url = match.group(1).strip("'")
        latest_version = path_url.split("_")[-1]
        download_url = BASE_URL + path_url + DOWNLOAD_FILE_PATTERN
        latest_bin = download_url.split("/")[1]
        print("The download URL cannot be found !")
        return package_updated
    print(f"Latest {app_name} version is: {latest_version}")
    print(f"Download URL is: {download_url}")
    # Downloading latest binaries
    if not isfile(latest_bin):
        print(f"Downloading: {latest_bin}")
        print(f"Binary is present: {latest_version}")
    if Version(latest_version) > Version(control.get_software_version()):
        print(f"Software version updated (from: {control.get_software_version()} to: {Version(latest_version)})")
        package_updated = True
        print(f"Software version up-to-date ({Version(latest_version)})")
    control.set_software_version(latest_version)
    # Deleting outdated binaries
    remove_outdated_binaries(latest_version)
    # Validating or not update-package-sources
Ich möchte anmerken, dass die Installation von Version 3.1.0 bei mir reibungslos verlief und die Software im Gegensatz zu Version 3.2.x wie erwartet funktioniert.
Ich denke, bevor wir die Software veröffentlichen, müssen wir sie testen, um sicherzustellen, dass sie wie erwartet funktioniert...
Flavien.
Allgemeine Informationen:
WAPT-Server: Debian 11, Version 2.4.0.14143, Enterprise Edition
Administrationsrechner: Windows 11, WAPT-Version 2.4.0.14143
