Paket: tis-adobereader
Veröffentlicht: 23. April 2015 - 10:45 Uhr
Beschreibung:
Adobe PDF Reader
Beschreibung:
Adobe PDF Reader
if iswin64():
key=reg_openkey_noredir(HKEY_LOCAL_MACHINE,r'SOFTWARE\Wow6432Node\Adobe\Adobe ARM\1.0\ARM',sam=KEY_WRITE,create_if_missing=True)
reg_setvalue(key,'icheckReader',0,REG_DWORD)
key=reg_openkey_noredir(HKEY_LOCAL_MACHINE,r'SOFTWARE\Adobe\Adobe ARM\1.0\ARM',sam=KEY_WRITE,create_if_missing=True)
print('Desactivation du module de mise a jour (cle de registre)')
key=reg_openkey_noredir(HKEY_LOCAL_MACHINE,r'SOFTWARE\Policies\Adobe\Acrobat Reader\11.0\FeatureLockDown',sam=KEY_WRITE,create_if_missing=True)
reg_setvalue(key,'bUpdater',0,REG_DWORD)
print('Desactivation du mode protege au demarrage (cle de registre)')
reg_setvalue(key,'bProtectedMode',0,REG_DWORD)
print('Desactivation de la protection renforcee (cle de registre)')
reg_setvalue(key,'bEnhancedSecurityStandalone',0,REG_DWORD)
print('Desactivation de la protection renforcee dans le navigateur (cle de registre)')
reg_setvalue(key,'bEnhancedSecurityInBrowser',0,REG_DWORD)
