[SOLVED] Problem Installing package .msi
Jitero
Registration: Apr 14, 2022 - 3:07 p.m.
April 27, 2022 - 3:53 PM
I get this error whenever I try to install a package in .msi format
Command 'msiexec /norestart /q /i "Visual Studio Code.msi" ' returned non-zero exit status 1603.
Installed WAPT version = 2.2.1
Server OS = Windows Server 2019
Administration/package creation machine OS = Windows 10
April 28, 2022 - 11:32
it's difficult to help you because error code 1603 means: Error 1603: A fatal error occurred during installation.
You would need to run the installation manually to understand the problem; an error message should appear and provide more information.
- Simon
AdriAlpes
Registration: July 1, 2020 - 12:19
April 29, 2022 - 3:28 PM
Can you try?
install_msi_if_needed('Visual Studio Code.msi',properties='ALLUSER=1 ALLUSERS=1')
Good afternoon!
