Hi Albin,
since you're defining variables, it's not possible to run them individually; you have to maintain the context.
In your last post, you have a "-WmiObject" command without the "Get"... It's normal that it crashes, probably an accidental copy-paste.
By the way, are you running `run_powershell_from_file` using `def session_setup()` or `def install()`? If it's using `def install()`, it's normal that it doesn't work; your code is context-dependent.
Regards,
Denis.
PS: Please put your code snippets and shell output in code blocks; it's much more readable.
[SOLVED] Problem executing a PowerShell script using the PowerShell run function
- WAPT Expert
I re-ran my script using the run_powershell_from_file command
here is the code
I'm getting errors in the console when I deploy to a machine.
Here are the errors:
Albin
here is the code
# Usable WAPT package functions: install(), uninstall(), session_setup(), audit(), update_package()
def session_setup() :
run_powershell_from_file("testwapt.ps1")Here are the errors:
File "C:\Program Files (x86)\wapt\common.py", line 3938, in install_wapt
AttributeError: module '__waptsetup_ttmou6pwdf__' has no attribute 'install'
Albin
- WAPT Expert
filecopyto('testwapt.ps1',r'c:\testwapt.ps1')
run_powershell_from_file(r"c:\testwapt.ps1")
We tested your script, we don't have any errors in the Wapt console, but it still doesn't work
The copy of the testwapt.ps1 file is successful on the machine, but the script does not execute.
Albin
Albin
- WAPT Expert
On the machine where the package was launched, you can do the following:
To see what that says
wapt-get session-setup nom_de_votre_paquet -fHello again,
I ran the command and I got this message
: Using config file: C:\Program Files (x86)\wapt\wapt-get.ini
Configuring testwapt.ps1 ...
2022-05-02 12:00:05,183 CRITICAL Exception: Package testwapt.ps1 is not installed
. Regards,
Albin
. Regards,
Albin
- WAPT Expert
Not the script, but the name of your package (package field in your package's control file)
I ran the command again with the package name.
Here's the message I got:
Configuring Printer_0-wapt ...
2022-05-02 16:17:16,250 CRITICAL Exception: Package Printer_0-wapt is not installed.
Regards,
Albin
Regards,
Albin
- WAPT Expert
You specified the folder in waptdev and not the package name
So, judging by the folder name, I assume your package name is "Printer"
SO:
SO:
wapt-get session-setup Imprimante -f
