Hello everyone, I'm new to the forum.
I've configured my WAPT server to distribute the OS via PXE. Since
the TFTP service is included, I didn't need to configure it.
When I boot a PC via PXE, I get the following error:
PXE-E3A: TFTP too many packages
Problem PXE-E3A: TFTP too many packages
- WAPT Expert
Hi juniormateus,
First version of wapt, server, etc. (see forum rules above)
For wads, please add dhcp type and configuration (uefi, legacy, etc.)
Can you reproduce this error on another computer or on virtualbox?
There was a bug on the filesize attribute that has been fixed in the last version (there was an extra NULL character at the end of the filesize, most tftp client don't care, but some get buggy with that.
Could you please try with the bugfix release of today wapt-2.2.1.11932-6522dccb to see if you can reproduce this issue just to be sure that it isn't a bug related to weird filesize interpretation?
Cheers,
Cheers,
juniormateus
- Registration: May 5, 2022 - 4:53 p.m.
thx for your quick answer i'll try update and let your know!
juniormateus
Hi, i've tried to upgrade, but it look like i'm already on the latest version!dcardon wrote: ↑May 05, 2022 - 7:01 p.m. Hi juniormateus,
Cheers,
tis-waptserver is already the newest version (2.2.1.11932-6522dccb-debian-11-amd64).
tis-waptsetup is already the newest version (2.2.1.11932-6522dccb-debian-10-amd64).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
- WAPT Expert
Can you downoad ipxe.efi file using a standard tftp client? cf https://www.wapt.fr/fr/doc/wapt-wads-tf ... erver.html
juniormateus
Yes, I can download using TFTPdcardon wrote: ↑May 06, 2022 - 11:36 Can you downoad ipxe.efi file using a standard tftp client? cf https://www.wapt.fr/fr/doc/wapt-wads-tf ... erver.html
- WAPT Expert
We can try to deactivate the wapt tftp to see if with the official debian tftp it is better
in /etc/default/tftpd-hpa add:
and run:
systemctl stop wapttftpserver
apt-get install tftpd-hpa
TFTP_USERNAME="tftp"
TFTP_DIRECTORY="/var/www/wads/pxe
TFTP_ADDRESS="0.0.0.0:69"
TFTP_OPTIONS="--secure"
systemctl start tftpd-hpa
- WAPT Expert
Have you tried?
