I have the Wapt Discovery version. I installed my Wapt server on a Windows Server 2019 VM.
I installed the console on my machine. I'm on the same VLAN as the server. I downloaded the Naps2 package, modified my machine, ran the update and installation, and the software installed without any problems on my machine.
However, I installed WaptAgent on a PC (different VLAN). This PC appears correctly in the console, I click "Upgrade" and then "OK," the inventories worked, and I can see everything related to this PC, but when I try to deploy npas2 or other packages, the software doesn't install.
Do you have any ideas?
Thank you.
[RESOLVED] Software does not install on all computers
