a WAPT server installed on a standard Windows 7 virtual machine.
I get this error message when I try to import a package from the internet:
=> Download canceled. :"" is an invalid integer.
I only get this message on this installation, and apart from this error message, all other features are working fine
. I've tried reinstalling it without success.
I tested the installation on a Windows server in a VM, and it worked perfectly, no problems.
Can you please help me?
[RESOLVED] Download canceled. :"" is an invalid integer
- WAPT Expert
- WAPT Expert
Where does the error occur?
Private repository? Package duplication? Inventory?
- WAPT Expert
Did you specify a proxy configuration in the console?
- WAPT Expert
This is not the correct syntax:
https://www.wapt.fr/fr/doc/Utilisation/ ... et-basique
http://srvproxy:8080
- WAPT Expert
Hello adgm11,
please avoid reviving very old posts (see necro-posting [1]). This one corresponds to version 1.3.13, and it's likely there's no connection between the two problems. You can start a new thread.
Regards,
[1] https://fr.wiktionary.org/wiki/necropost
Regards,
