[RESOLVED] Download canceled. :"" is an invalid integer
seb
Registration: December 11, 2017 - 11:31
December 11, 2017 - 11:39
a WAPT server installed on a standard Windows 7 virtual machine.
I get this error message when I try to import a package from the internet:
=> Download canceled. :"" is an invalid integer.
I only get this message on this installation, and apart from this error message, all other features are working fine
. I've tried reinstalling it without success.
I tested the installation on a Windows server in a VM, and it worked perfectly, no problems.
Can you please help me?
December 11, 2017 - 11:50
which version are you using?
viewtopic.php?t=472
seb
December 11, 2017 - 11:58
Version 1.3.13.0
December 11, 2017 - 12:17
Where does the error occur?
Private repository? Package duplication? Inventory?
seb
December 11, 2017 - 12:33
Private repository => Import from internet => Right-click on the desired file => Import.
Confirmation message: "Are you sure you want to [blabla]?"
=> Yes.
And then an error message: "Download canceled. :"" is an invalid integer."
December 13, 2017 - 12:32
Did you specify a proxy configuration in the console?
seb
December 15, 2017 - 1:17 PM
Hello, sorry I was very busy with something else.
Yes, I specified the proxy in this format: xxx.xxx.xxx.xxx:xxxx
adgm11
Registration: Apr 12, 2022 - 07:00
June 25, 2022 - 12:37
Hello, what is the correct proxy configuration to enter in the console settings? I've entered 172.16.0.1:4512
, but this blocks my access to the console and the local repository.
June 27, 2022 - 10:36
Hello adgm11,
please avoid reviving very old posts (see necro-posting [1]). This one corresponds to version 1.3.13, and it's likely there's no connection between the two problems. You can start a new thread.
Regards,
[1] https://fr.wiktionary.org/wiki/necropost
