- Server OS: Debian 10
- DHCP Server: Win19 Server
- Operating system of the administration/package creation machine: Windows Server 19
I'm trying to create a package to install a registry key.
from setuphelpers_windows import *
pass
pass
def session_setup():
registry_set(HKEY_CURRENT_USER, r"SOFTWARE/Microsoft/Internet Explorer/BrowserEmulation/ClearableListData", 'UserFilter', '41,1f,00,00,53,08,ad,ba,03,00,00,00,8c,00,00,00,01,00,00,00,03,00,00,00,0c,00,00,00,61,b0,8c,da,26,49,d6,01,01,00,00,00,0f,00,31,00,36,00,34,00,2e,00,31,00,33,00,38,00,2e,00,32,00,34,00,32,00,2e,00,31,00,39,00,37,00,0c,00,00,00,80,a6,a4,f5,fb,55,d6,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,36,00,37,00,0c,00,00,00,07,6d,09,61,c6,ae,d7,01,01,00,00,00,0b,00,31,00,30,00,2e,00,31,00,34,00,37,00,2e,00,30,00,2e,00,35,00,38,00', type=winreg.REG_BINARY)
print ('Installation de la clé de registre GCE')
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2974, in call_setup_hook
hookdata = hook_func()
File "c:\waptdev\keyregistry-GCE_0_PROD-wapt\setup.py", line 12, in session_setup
registry_set(HKEY_CURRENT_USER, r"SOFTWARE/Microsoft/Internet Explorer/BrowserEmulation/ClearableListData", 'UserFilter', '41 1f 00 00 53 08 ad ba 03 00 00 00 8c 00 00 00 01 00 00 00 03 00 00 00 0c 00 00 00 61 b0 8c da 26 49 d6 01 01 00 00 00 0f 00 31 00 36 00 34 00 2e 00 31 00 33 00 38 00 2e 00 32 00 34 00 32 00 2e 00 31 00 39 00 37 00 0c 00 00 00 80 a6 a4 f5 fb 55 d6 01 01 00 00 00 0b 00 31 00 30 00 2e 00 31 00 34 00 37 00 2e 00 30 00 2e 00 36 00 37 00 0c 00 00 00 07 6d 09 61 c6 ae d7 01 01 00 00 00 0b 00 31 00 30 00 2e 00 31 00 34 00 37 00 2e 00 30 00 2e 00 35 00 38 00', type=winreg.REG_BINARY)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3825, in registry_set
return reg_setvalue(key, keyname, value, type=type)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 447, in reg_setvalue
return winreg.SetValueEx(key, name, 0, type, value)
TypeError: Objects of type 'str' can not be used as binary registry values
