WUA: Clarification on the parameters
smandel
Registration: May 5, 2022 - 11:30
June 29, 2022 - 3:12 PM
I would have liked some clarification on the agent settings for WUA.
For example :
download_scheduling=2h
install_scheduling=4h
These parameters are recurring according to the documentation.
But is this a recurrence based on the time?
For example, for an installation parameter of "4h" this means: installation at 4 AM - 8 AM - 12 PM - 4 PM,...
Or every 4 hours after the station starts?
THANKS.
June 29, 2022 - 10:14 PM
If more than 4 hours have passed since its last execution, then the task will run.
Note that we recently added a 10-minute delay after system startup to avoid overloading Windows at boot time; therefore, you may sometimes have to wait 10 minutes after booting.
I should also mention that Microsoft releases a wsusscn2.cab file once a month, so a scan every 7 days should logically be sufficient (even less).
smandel
June 30, 2022 - 2:25 PM
So a computer that starts up in the morning will necessarily install the updates very quickly?
Thank you.
