[SOLVED] PC appears disconnected since update to 2.2
July 6, 2022 - 2:26 PM
What version of PostgreSQL is currently running (not the installed versions)?
sudo -u postgres psql template1 -c "SELECT version();"
Could you retrieve the exception corresponding to the error returned ("ERROR: syntax error on or near...") in /var/log/waptserver.log.
By the way, it seems your server is installed in a French locale, which doesn't meet the documentation requirements... It's not best practice...
Alex
Registration: Apr 26, 2016 - 09:49
July 7, 2022 - 09:11
- The version is PostgreSQL 9.4.19
- Here's what I retrieved from the logs:
Jul  3 00:04:05 EOS waptserver[1047]: 2022-07-03 00:04:05,930 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...519b9b0-d697-11e7-8d03-000c2954dc5e', 1656799445) ON CONFLIC...\n                                                             ^\n")
Jul  3 00:04:06 EOS waptserver[1047]: 2022-07-03 00:04:06,936 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...519b9b0-d697-11e7-8d03-000c2954dc5e', 1656799446) ON CONFLIC...\n                                                             ^\n")
Jul  3 00:04:07 EOS waptserver[1047]: 2022-07-03 00:04:07,399 [waptdb         ] CRITICAL Unable to update installed_softwares for 4C4C4544-0053-5210-804C-B6C04F32344A: ProgrammingError: ERREUR:  erreur de syntaxe sur ou près de « on »
Jul  3 00:04:07 EOS waptserver[1047]: LINE 3:               on conflict (host_id,software_id) do update
- Regarding the language, I just switched back to LANG=en_US.UTF-8
July 7, 2022 - 6:11 PM
You need at least PostgreSQL 9.6. Please upgrade PostgreSQL (by default, Debian installs the new version during a major distribution upgrade but doesn't switch over and keeps the old version in production on port 5432).
Regards,
Alex
July 8, 2022 - 11:32
Like this?
9.4 main    5432 online postgres /var/lib/postgresql/9.4/main /var/log/postgresql/postgresql-9.4-main.log
11  main    5433 online postgres /var/lib/postgresql/11/main  /var/log/postgresql/postgresql-11-main.log
But that doesn't change anything... is there a specific procedure to follow?
July 8, 2022 - 7:28 PM
The problem doesn't depend on wapt, but on the Debian upgrade process. You need to use the `pg_upgradecluster` command to update the data to version 11.
You can refer to:
https://gist.github.com/dmitrykustov/27 ... c830910019.
At the end of the process, it should be PostgreSQL 11 listening on port 5432 with the wapt database, and you can then remove the PostgreSQL 9.4 packages.
Alex
July 11, 2022 - 09:21
Ah, after that, it's much better! The upgraded machines are now showing as OK!
Thank you so much.
Have a good day.
July 11, 2022 - 09:28
Okay, good news. So the problem was that the Postgres database hadn't been upgraded during the Debian distribution upgrade. As a reminder, you need Postgres version 9.6 or higher to run the WAPT server.
I'm marking this as resolved.
Regards,
