[SOLVED] False negative .exe installation
florian777
Registration: Apr 13, 2022 - 09:53
July 21, 2022 - 1:08 PM
I am currently working on a package for the SRS software.
Basically, I launch the executable with its silent installation parameter, except that wapt informs me that the installation has failed:
waptutils.CalledProcessErrorOutput: Command 'InstallSRS.exe /S' returned non-zero exit status 1223.
However, the software installed correctly and runs properly on the client machine. Is there a way to manually change the status to "OK"?
Geoffroy
Registration: June 28, 2022 - 3:34 PM
July 21, 2022 - 2:01 PM
In my opinion, the silent flag argument is not valid.
Contact the publisher to get the correct argument.
Server: WAPT Enterprise 2.6.0.17226 on Debian 12;
Consoles: Windows 11
; Infrastructure: Windows
florian777
July 21, 2022 - 2:06 PM
The silent flags are good
July 21, 2022 - 2:54 PM
