[RESOLVED] Meshcentral Agent
smandel
Registration: May 5, 2022 - 11:30
September 12, 2022 - 12:13
I am trying to deploy the Meshcentral agent using the tis-mesh-template package.
So I managed to get the agent installation unstuck; it was stuck because the mesh agent executables were showing a version "0.0.0.0".
So there shouldn't be any problems with the installation.
However, when I try to uninstall it from the console, I get this message:
...Checking for previous installation of "\"Mesh" [NONE]
and subsequently the following error message and no uninstallation of the agent:
Waiting for the removal of key: Mesh Agent from Windows registry
Fatal error : Uninstallkey still present
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1894, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 692, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1286, in _run
    self.result = self.wapt.remove(self.packagenames,
  File "C:\Program Files (x86)\wapt\common.py", line 5500, in remove
    setuphelpers.error('Uninstallkey still present')
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1907, in error
waptutils.EWaptSetupException: Fatal error : Uninstallkey still present
    self._run()
Whereas I have no problems when I run the "uninstall" of the package under Pyscripter.
So I have the impression that the "uninstall" function of the package is not used during an uninstallation via WAPT.
THANKS.
Best regards.
jpele
Registration: March 4, 2019 - 12:01
September 12, 2022 - 2:58 PM
It's likely you're testing the uninstallation via the Console on the development machine where you created and tested the package. That's why the installation isn't detected in the Console. I suggest you test it on another machine to validate the installation.
There is a print statement to that effect, which was displayed at the time of installation via PyScripter.
    if not running_as_system():
        print("WARNING: %s will NOT be installed as SYSTEM account, it may cause issues" % app_name)
Jimmy
smandel
September 12, 2022 - 3:16 PM
thank you for your reply.
I'm actually testing the package locally with PyScripter, then I upload it to the server and assign it to my PC.
The installation goes smoothly, as does the audit; it correctly retrieves all the information, including the ID for logging in via the WAPT console.
However, when I try to uninstall it via the WAPT console, I get these error messages, whether on my machine or another.
The uninstallation seems to launch the "remove" command and not the "uninstall" command.
The problem is, I have no control over what happens during the "remove" process.
Thank you.
Best regards.
smandel
September 12, 2022 - 3:46 PM
Okay, I think I've just found it...
In fact, the agent's executable creates a bad "UninstallString" in the registry:
C:\Program Files\Mesh Agent\MeshAgent.exe -funinstall --meshServiceName="Mesh Agent"
The correct string is as follows:
C:\Program Files\Mesh Agent\MeshAgent.exe -fulluninstall
I must be on a buggy version... (meshcentral server version 1.0.85)
smandel
September 12, 2022 - 3:59 PM
So, to solve the problem, I added the following to the end of install():
registry_set(HKEY_LOCAL_MACHINE,"SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\Mesh Agent","UninstallString","C:\Program Files\Mesh Agent\MeshAgent.exe -fulluninstall")
jpele
September 12, 2022 - 4:16 PM
That's likely, as the tests were done on versions 0.9.84 and 1.0.0 (not certain).
I'll test it again anyway; it's been a while since I checked this package.
Please feel free to provide any additional information you may have, which could help us improve the package.
smandel
September 12, 2022 - 5:42 PM
So, based on my tests for the moment, it's best to stay on the stable version 1.0.0:
npm install meshcentral@1.0.0
At the WAPT level, add the previous key to the "install()".
And in the audit() function, add a 15-second sleep at the beginning to ensure the registry keys are created correctly:
time.sleep(15)
jpele
September 16, 2022 - 4:24 PM
Indeed, version 1.0 seems safer.
For your information, you can switch releases graphically from the web interface.
2022-09-15 16_22_20-MeshCentral.png (97.79 KB) Viewed 14077 times
The package has been updated; here is the changelog:
0.2.1.3-80
Package can now be fully customized interactively with update_package
Configuration is now based on JSON file "mesh-conf.json" graphically edited in update_package
Now using persistent folder to call JSON file locally with get_persistent_package_file()
Autofilling impacted_process
Fix uninstall by adding QuietUninstallString
Jimmy
