Wapt Enterprise 2.2.3 Windows Active Directory environment.
I'm having a problem with my secondary repositories. We have three sites: one primary and two remote.
On the primary site, there's the console and server;
on the secondary sites, there are the repositories.
The rules are working, and the workstations are correctly placed in the right location.
The problem we're encountering is that we have to put the packages in the root of the OU for them to be installed on the workstations.
This means we can't install them on a case-by-case basis.
Is this normal, or is there a problem somewhere?
Thank you for your feedback.
[RESOLVED] Secondary repository
- WAPT Expert
Good morning
Sorry, I didn't quite understand the issue.
Do you mean that only the OR configurations work?
Bous sommes obligés de mettre les pacquet à la racine de l'OU pour que celui soit installé sur les postes.
- WAPT Expert
Do you synchronize packets between machines at remote sites? Do the workstations see the packets on the server, or only the repository?
Regards,
Regards,
