[SOLVED] Discord launch error
Geoffroy
Registration: June 28, 2022 - 3:34 PM
October 5, 2022 - 1:23 PM
when trying to install Discord via the console on your repository,
it installs correctly, but we get an error when opening it.
Wapt Enterprise 2.2.3, Windows environment
discord error.png (12.63 KB) Viewed 3935 times
Server: WAPT Enterprise 2.6.0.17226 on Debian 12;
Consoles: Windows 11
; Infrastructure: Windows
October 6, 2022 - 10:11
Hi Geoffroy,
You need to force-close the Discord application to update it, which the Discord installer doesn't support, and which the package doesn't seem to do either to compensate for the installer's shortcomings. The way the Discord application is developed/packaged is pretty poor, but this should still be taken into account.
I'm submitting an internal ticket to fix the problem and marking the topic as resolved.
Best regards,
