WAPT Enterprise 2.2 Windows Environment
I am getting an error message when installing this package.
File "C:\Program Files (x86)\wapt\common.py", line 4063, in install_wapt
File "C:\Users\admzi\AppData\Local\Temp\wapt_x22u3y7\setup.py", line 17, in install
File "C:\Program Files (x86)\wapt\common.py", line 3840, in run
File "C:\Program Files (x86)\wapt\waptutils.py", line 2138, in run
waptutils.CalledProcessErrorOutput: Command 'C:\\Windows\\System32\\certutil.exe -addstore TrustedPublisher oracle.crt' returned non-zero exit status 2147942402.
Output:TrustedPublisher "╔diteurs approuvÚs"
Impossible dÆouvrir de magasin de certificats existant. Utilisez lÆoption -f
pour forcer la crÚation du magasin de certificats.
CertUtilá: -addstore ╔CHEC de la commandeá: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
CertUtil: Le fichier spÚcifiÚ est introuvable.
