BIOS Update - Variables
lfkl
Registration: Apr 11, 2019 - 05:51
November 22, 2022 - 03:42
I'm trying to deploy a BIOS update package on desktops and laptops.
I have two problems:
1) How can I include a variable in the package that takes into account the compatible machine model(s) (given that our fleet is relatively homogeneous)?
For example, the BIOS-1 package runs on our DELL Optiplex 3050 and 3070 laptops, and BIOS-2 on the DELL Latitude laptops.
2) Regarding laptops, is it possible to include an additional condition that considers whether the battery level is above XX%?
It's not so simple…
Thank you for your insights and examples (I'm not very proficient in Python).
Have a good day.
florentR2
Registration: February 13, 2020 - 5:23 PM
November 22, 2022 - 9:52 AM
If it's for a Dell, it's best to use Dell Command Update, which will automatically select the correct drivers and BIOS for the model.
Regarding the battery level, it normally won't do anything if the machine isn't plugged in (at least not on Dell and HP machines).
olaplanche
Registration: January 26, 2017 - 11:11
November 22, 2022 - 2:18 PM
Personally, I created one package per model. Otherwise, to answer your question:
1) It is possible to retrieve the machine model directly from the package using the following code, for example:
wmi_data = wmi_info(keys=['Win32_ComputerSystem'])['Win32_ComputerSystem']
print(wmi_data['Model'])
2) For the battery, you need to use the battery_percent function:
battery = battery_percent()
print(battery)
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
lfkl
November 23, 2022 - 1:48 AM
Thanks to both of you for your replies.
@florent2: Yes, that's pretty much what I thought, namely that the battery level is already checked in the Dell installer.
Actually, I should test it with a laptop connected via Wi-Fi to be sure.
@olaplanche
Thanks for the codes, they'll help.
Have a good day.
