[SOLVED] windows10-upgrade-template_0-110 in 22H2
dj41ph4
Registration: Oct 26, 2022 - 2:02 p.m.
December 23, 2022 - 10:29 PM
I'm using WAPT 2.2 Enterprise on Debian 11.5
and I'd like to use the Windows 10 update template. I'm following the instructions for downloading the ISO, but then I get an error.
Have you ever succeeded with version 22H2?
Thanks in advance
. Best regards,
dj41ph4
December 26, 2022 - 8:35 AM
I took a screenshot,
I don't know where the upload logs are located
Thank you for your help
Yours sincerely
December 26, 2022 - 5:31 PM
does it work when you run `update_package` from a PyScripter?
Regards,
December 29, 2022 - 11:57
We do have a small problem with this package regarding the upload.
The update package runs correctly through the console, but because it's placed in the temp directory, it reaches a filename length limit, and the build fails.
Running the update package through the code editor places the package in c:\waptdev\, and therefore it works because the path is shorter.
We need to find a solution,
Simon.
December 29, 2022 - 12:54
The problem has been fixed internally on the master version 2.3, so it will work in the next version
dj41ph4
January 9, 2023 - 11:32
I've just returned to work
, and it works via PyScripter.
Thank you for everything.
