have you experienced a similar problem?
Wapt, the agent, is not communicating with our server, affecting mostly a few Linux workstations.
Thank you.
[SOLVED] Linux: Wapt and server "the agent is not communicating with our server"
- WAPT Expert
Hello kubectl__,
what version, OS, etc.? See the forum rules...
and a little more information wouldn't hurt, because with so little we're going to have to consult a psychic, I think unfortunately...
Regards,
Regards,
thank you. I
using Linux on Ubuntu 22.04
with Wapt version 2.2.3.12485.
I would appreciate some information on the forum rules, please.
Nothing appears in the Wapt console regarding Ubuntu Linux.
There's nothing in the Ubuntu Linux logs either.
I'll look into it on my end, thank you.
Please excuse me, I'm a beginner, especially with Wapt and in the IT field.
In the future, I'll be more careful to provide more detailed information to get a more accurate response.
thank you. I
- WAPT Expert
Hello kubectl__,
What happens with a register?
Denis Cardon
The forum rules are in the big red block at the top of this thread... (we considered making it flashing red, but well, that would have been a bit aggressive)
The WAPT agent under Linux does not have a default configuration. You must configure the wapt-get.ini file.
wapt-get registerDenis Cardon
- WAPT Expert
Well, since I haven't received a response, I consider the matter resolved.
Regards,
Regards,
