[RESOLVED] CheckPackageSignature Error
FabienG
Registration: January 23, 2023 - 3:10 PM
January 23, 2023 - 3:42 PM
following the 2.3 update, I'm encountering a problem with all my packages when I try to edit, re-sign, or upload them.
The message I get when I try to re-sign a package is: "CheckPackageSignature failed for ccg-TEST(=0-2). WAPT Certificate Signer: ."
When I try to modify a package group and click "Build Upload": "Error when uploading package: CheckPackageSignature failed for ccg-nouveau_laptop(=20). WAPT Certificate Signer: ."
When I click "Edit package in editor," I get the same message: "CheckPackageSignature failed for ccg-ennov(=0-1). WAPT Certificate Signer: ."
A screenshot is attached.
I can create a new package and sign it, but then I can no longer edit it.
My personal certificate is named "WAPT Certificate."
Application deployment works without any problems.
I'm really stuck.
Thanks for your help, suggestions...
Fabien
Context:
- WAPT v2.3 (previously 2.2)
- Windows Server 2019
- Machine OS: Windows 10 Console
Uploading packages.png (11.21 KB) Viewed 4159 times
x-davidl
Registration: Apr 25, 2022 - 5:07 p.m.
January 24, 2023 - 10:56
could you please take a look at my post in the forum? It might help:
WAPT usage (Console, Agent) / WAPT usage (Console, Agent).
You need to re-upload your private certificate to
C:\Program Files (x86)\wapt\ssl
on the computer from which you launch the console
. Regards.
FabienG
January 24, 2023 - 12:50
it works!!!!!
Thank you so much
, Fabien
