[SOLVED] Installing tis-powershell
flipflip
Registration: May 31, 2022 - 09:05
January 24, 2023 - 4:57 PM
Hello everyone,
I'm exploring Wapt 2.3.0.13438 Discovery before permanently migrating my package deployment. For now, I'm using the Kaspersky admin console to do this.
I'm having a problem with the tis-powershell (7.3.1-10) package. Its dependencies include powershell-5.1-15, which requires dotnetfx, which requires dotnetfx4.8. I've downloaded all these dependencies and added them to the host package on my test machine
I click on "Save and apply". The installation starts but results in an error for each sub-package.
Installing hil_-powershell(=7.3.1-20)
Installing: hil_-powershell5
Installing hil_-dotnetfx(=4.8.1-24)
Installing hil_-powershell5(=5.1-15)
Erreur lors de l'installation de ['hil_-powershell(=7.3.1-20)']: erreurs dans les paquets [[PackageRequest(package='hil_-powershell',version=(Version('7.3.1.0'), 20),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-7', 'win-7', 'w-7', 'windows7', 'win7', 'w7', 'windows', 'win', 'w'],min_os_version=Version('6.1.7601.24544'),max_os_version=Version('6.1.7601.24544')), PackageEntry('hil_-powershell','7.3.1-20' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5193, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4167, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4074, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Windows\\TEMP\\wapt22ix2lhn\\setup.py", line 19, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 7007, in audit\n    raise Exception(\'Package %s is not installed\' % package)\nException: Package hil_-powershell5 is not installed\n']]
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1907, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 710, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1282, in _run
Exception: Erreur lors de l'installation de ['hil_-powershell(=7.3.1-20)']: erreurs dans les paquets [[PackageRequest(package='hil_-powershell',version=(Version('7.3.1.0'), 20),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-7', 'win-7', 'w-7', 'windows7', 'win7', 'w7', 'windows', 'win', 'w'],min_os_version=Version('6.1.7601.24544'),max_os_version=Version('6.1.7601.24544')), PackageEntry('hil_-powershell','7.3.1-20' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5193, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4167, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4074, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Windows\\TEMP\\wapt22ix2lhn\\setup.py", line 19, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 7007, in audit\n    raise Exception(\'Package %s is not installed\' % package)\nException: Package hil_-powershell5 is not installed\n']]
    self._run()
It's as if the dependencies and/or the installation order were not respected (or there's something I haven't understood).
So I wanted to install at least dofnetfx4.8, I removed the other packages from the host package
The installation restarted but it's as if it didn't take into account the modification of the host package and it's trying again to install all the packages (I can't attach a 4th image to this post).
Have I missed some subtlety?
Wapt: 2.3.0.13438
Wapt-agent: 2.3.0
Server: Debian 11
Target operating system: Windows 7 64-bit
Thanks in advance.
January 25, 2023 - 12:09
the tis-powershell package installs the latest version, and is therefore redundant and conflicts with the tis-powershell5 package which installs version 5. You must use one or the other.
Regards,
flipflip
January 25, 2023 - 5:53 PM
Hello and thank you for your reply.
Having experienced strange behavior on my test PC, I decided to remove it from the WAPT inventory, uninstall the agent and the console (they're on the same machine), and redo the agent and console deployment process, rebooting between each step.
- The PC registers successfully with the server;
- I'm launching the deployment of the powershell 7 package all by myself;
- I'm monitoring the processes but nothing is coming to fruition;
- I go back to the console and everything is pending...
It's 5:45 PM when I took the screenshot. So it's been waiting for 15 minutes, and another problem is the message: Unable to retrieve the action...
I'm going to dig around a bit in the C:\Program Files (x86)\wapt\logs directory, I open the waptservice.log file and surprise: there is indeed a problem.
2023-01-25 17:45:59,666 [wapttasks WaptTaskManager 2000] WARNING Host on the server is not known or not known under this FQDN name (known as monpc.mo.domain). Trying to register the computer...
And the file is full of them. If I understand correctly, there's a problem with the DNS part. I'm running basic tests
nslookup serverWapt --> ça marche
ping serverWapt --> ça marche
ping serverWapt.mon.domain --> ça marche
nslookup monpc --> ça marche
ping monpc --> ça marche
nslookup monpc.mon.domain --> ça marche
ping monpc.mon.domain --> ça marche
ping IP.DE.MON.PC --> ça marche
I perform the same tests from the wapt server and everything is OK.
I've tested pretty much everything on the DNS and network side, for me everything is working.
Have I missed something?
x-davidl
Registration: Apr 25, 2022 - 5:07 p.m.
January 27, 2023 - 10:42
I suggest you re-register your post
in a command prompt window (command prompt admin)
using `wapt-get register`.
If this creates a duplicate, properly delete the "old" post
. Regards.
flipflip
January 30, 2023 - 1:44 PM
The wapt-get register did not create any duplicates and the machine is still in a strange state.
2023-01-30 12:00:22,262 [wapttasks WaptTaskManager 6412] WARNING Host on the server is not known or not known under this FQDN name (known as my.MY.DOMAIN). Trying to register the computer...
2023-01-30 12:00:53,827 [wapttasks WaptTaskManager 6412] INFO Got signed certificate from server. Issuer: waptserver. CN: RND-72669821-65F2-436E-B09C-0B153AAC7155
2023-01-30 12:00:53,889 [wapttasks WaptTaskManager 6412] INFO Save host key to C:\Program Files (x86)\wapt\private\RND-72669821-65F2-436E-B09C-0B153AAC7155.pem
2023-01-30 12:00:53,889 [wapttasks WaptTaskManager 6412] INFO Save host cert to C:\Program Files (x86)\wapt\private\RND-72669821-65F2-436E-B09C-0B153AAC7155.crt
2023-01-30 12:00:53,998 [wapttasks WaptTaskManager 6412] INFO New registration successful. Retring sending host status.
2023-01-30 12:00:53,998 [wapttasks WaptTaskManager 6412] INFO Reloading waptcore configuration for Wapt instance thread 6412
2023-01-30 12:00:55,777 [wapttasks WaptTaskManager 6412] INFO update_server_status successful (data size 2407)
2023-01-30 12:00:55,777 [wapttasks WaptTaskManager 6412] WARNING Host on the server is not known or not known under this FQDN name (known as my.MY.DOMAIN). Trying to register the computer...
I restarted the wapt service on the machine from the console but nothing changed.
January 30, 2023 - 4:57 PM
Can you remove your machine from the console?
then make a
net stop waptservice
wapt-get register
net start waptservice
Note that the "task" tab in the console can sometimes lose connection; simply switch tabs to try and regain the connection
flipflip
January 30, 2023 - 5:29 PM
I've also wondered about this, but I don't even know how the WAPT agent retrieves the domain. My network's IP addressing and all network settings are managed by a DHCP server (Linux), which provides all the configuration and the search domain (in lowercase). Does WAPT perhaps retrieve the domain in the Windows sense? If so, then I understand the uppercase/lowercase distinction because the machine's Windows domain is indeed written in uppercase. Although, in this case, it doesn't seem very logical to differentiate between case.
On my test machine, when I view the network adapter's configuration details (Control Panel > Network and Sharing Center > Network Connection Details), the "Connection-specific DNS Suffix" setting is indeed in lowercase.
On my test machine, I uninstalled everything (agent and console, since it's the same machine), deleted the last directories related to WAPT, rebooted the machine, and reinstalled everything, but I still get the same result.
flipflip
January 30, 2023 - 6:05 PM
Oops, our answers crossed.
@sfonteneau, your suggestion allowed me to correctly reinstall the machine in the console. So I launched the PowerShell package installation while monitoring the machine's Windows Task Manager. I can clearly see the waptpython process going haywire for several seconds, then nothing.
I went back to the console after waiting 30 minutes without doing anything on the machine, but everything is still pending
I checked the event viewer on the test machine and I found this in the logs:
Nom de l’application défaillante waptpython.exe, version : 3.8.16150.1013, horodatage : 0x638fbd39
Nom du module défaillant : python38.dll, version : 3.8.16150.1013, horodatage : 0x638fbd0f
Code d’exception : 0xc0000005
Décalage d’erreur : 0x001e48ba
ID du processus défaillant : 0x184c
Heure de début de l’application défaillante : 0x01d934bbb5f93917
Chemin d’accès de l’application défaillante : C:\Program Files (x86)\wapt\waptpython.exe
Chemin d’accès du module défaillant: C:\Program Files (x86)\wapt\python38.dll
ID de rapport : 39ba0bdf-a0ba-11ed-815a-0800278aa4f7
