I have a package containing a shortcut file (.lnk, therefore).
Until now, this hadn't been a problem.
I'm editing this package to add a few lines to setup.py (nothing to do with the lines that deal with the lnk file).
I compile it and then when I try to install:
File "C:\Program Files (x86)\wapt\common.py", line 3956, in install_wapt
packagetempdir = entry.unzip_package(cabundle=self.cabundle, target_dir = tempfile.mkdtemp(prefix='wapt',dir=self.wapt_temp_dir))
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2623, in unzip_package
raise e
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2615, in unzip_package
verified_by = self.check_package_signature(cabundle,ignore_missing_files=ignore_missing_files)
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2573, in check_package_signature
raise EWaptCorruptedFiles('Error in package %s in %s, files corrupted, SHA not matching for %s' % (self.asrequirement(), self.sourcespath, errors,))
waptpackage.EWaptCorruptedFiles: Error in package La_Normandise(=2023.1.30-1) in C:\WINDOWS\TEMP\waptqkryxmf8, files corrupted, SHA not matching for ['Téléphones.lnk', 'C:\\WINDOWS\\TEMP\\waptqkryxmf8\\Téléphones.lnk']
Nothing to do.
Any ideas?
