I'm setting up secondary repositories on all sites.
Everything works with the secondary repositories themselves.
However, in the agent configuration, `use_repo_rules` is always set to `false`.
I've regenerated the agent several times, checking the "Use repository access rules" option, but it doesn't change anything.
Have I missed something?
Thanks!
PS: I'm on version 2.3 on a Debian Buster server.
[SOLVED] wapt agent and repo_rules
- WAPT Expert
could you please specify whether you are using the enterprise version of wapt (licensed version), or the discovery version?
In the enterprise version, but indeed, by retrieving the wapt-conf-policy package and adapting it for my needs, I was able to set the use_repo_rules variable to False everywhere.
Now I don't understand why my agents are finding 0 available packages on the remote repositories even though the rules are configured and synchronization is complete.
I don't know if this will help, but I had a problem with my rules.guigeek wrote: ↑March 3, 2023 - 2:44 PM in the enterprise version, but indeed, by retrieving the wapt-conf-policy package and adapting it for my needs, I was able to set the use_repo_rules variable to False everywhere.
Now I don't understand why my agents are finding 0 available packages on the remote repositories even though the rules are configured and the synchronization is also in place.![]()
For example, if I used the IP address 192.168.0.1/13 to retrieve all IP addresses in the 192.168.XX range, it didn't work, but using 192.168.0.0/13 worked immediately.
Debian 11
WAPT Version: 2.4.0.14143
- WAPT Expert
That's normal then: https://mxtoolbox.com/subnetcalculator.aspxjdziadek wrote: ↑March 6, 2023 - 12:48I don't know if this will help, but I had a problem with my rules.guigeek wrote: ↑March 3, 2023 - 2:44 PM in the enterprise version, but indeed, by retrieving the wapt-conf-policy package and adapting it for my needs, I was able to set the use_repo_rules variable to False everywhere.
for 192.168.0.1/13 192.168.0.1 is not valid
- WAPT Expert
In the agent's repository tab, is the correct repository appearing?guigeek wrote: ↑March 3, 2023 - 2:44 PM in the enterprise version, but indeed, by retrieving the wapt-conf-policy package and adapting it for my needs, I was able to set the use_repo_rules variable to False everywhere.
Yes, it's definitely the right repo!
And in the tasks, we can clearly see that it's searching the correct repo and finding a significant number of packages to examine... but it doesn't see any packages to update, even though there are some!
