[SOLVED] Unable to import Cura from the store
Marceld
Registration: March 22, 2023 - 1:19 PM
April 20, 2023 - 10:56
Good morning
I am unable to import from the wapt CURA store.
Here is the error:
I have no problem importing other applications.
Do you have any idea?
Thanks in advance
April 25, 2023 - 11:37
the CURA package is part of the WAPT Enterprise store, which is accessible to all customers with a current WAPT Enterprise license. The WAPT Enterprise store is currently in beta. If you have a WAPT Enterprise license, you can contact your technical or sales representative to generate your login credentials and download the package (and other packages from the WAPT Enterprise store) :-)
. Sincerely,
