WAPT Enterprise 2.4.0.14031-1420892a - Winserver2k16 - Win10 Admin
I updated to version 2.4, and when importing packages from your store, there's now a Package Cart and then Add/Remove from Cart.
I never noticed it before, but this detail jumped out at me after the update.
Should we infer that you're going to change your business model? (Charge packages imported from your store?)
Thank you
[RESOLVED] Package from the WAPT store
- WAPT Expert
the new feature allows you to add packages you want to duplicate to a "Cart," which lets you perform a new search without losing your selection. Previously, you had to select multiple packages, which wasn't practical and made searching difficult.
So, there's no change in that regard.
Among the changes that have been in place for some time now:
Certain new packages in the store are now reserved for Wapt Enterprise customers. You need a store account to download them. For example: https://wapt.tranquil.it/store/fr/tis-phylogenia
This isn't a purchase; it's simply additional packages reserved for Enterprise customers only.
