[SOLVED] Using a single console installation for multiple servers
Welsh
Registration: December 6, 2022 - 9:44 AM
June 20, 2023 - 11:48
first of all, sorry if this question has already been asked or if the answer can be found in the documentation, but I haven't been able to find it. :oops:
How can I configure my console to manage specific servers (which have no connection to each other) when needed?
I suppose it's related to the %localappdata%\waptconsole\waptconsole.ini configuration file by declaring a second [global] class, but I'm not sure.
Could you please help me?
Thank you in advance.
Baptiste
- 1 WAPT 2.5.5.15602 Enterprise server (3000 workstations) + 1 WAPT 2.4.0.14058 Enterprise server (10000 workstations)
- WAPT server OS: Linux REHL 8.7
- Administration/package creation machine OS: Windows Server 2019 v1809
June 20, 2023 - 3:46 PM
Hi Baptiste,
when you launch the console, before logging in you can modify the value in the "configuration" field and it will open a new dialog box where you can enter a new configuration.
Regards,
Welsh
June 20, 2023 - 3:52 PM
Hi Denis,
I saw that window, I didn't think it would create a second configuration so I could switch between the two. ;-)
I'll test that, thanks a lot, ;-)
Baptiste
June 20, 2023 - 5:11 PM
Thanks for the feedback, I'm marking the topic as resolved, :-)
