[RESOLVED] SHA on Version 1480
Geoffroy
Registration: June 28, 2022 - 3:34 PM
June 23, 2023 - 12:30
Wapt 2.41480
Debian
update
Windows Server console, the issue persists.
Have you received any other feedback on this?
2023-06-23 12_27_52-GCFRLYWAPTCONS - 10.1.0.45 - Remote Desktop Connection.png
2023-06-23 12_27_52-GCFRLYWAPTCONS - 10.1.0.45 - Remote Desktop Connection.png (7.52 KB) Viewed 5191 times
Server: WAPT Enterprise 2.6.0.17226 on Debian 12;
Consoles: Windows 11
; Infrastructure: Windows
June 23, 2023 - 12:55
I just figured out the problem you're having; we hadn't noticed it before.
Here's the issue:
You're editing a package using "edit in editor," but this package is already in waptdev.
The package in waptdev has the file setup.cpython-38.pyc.
The console rechecks the sum of what it just downloaded for security reasons, but an unexpected file is in the folder.
In your case, you either need to delete the old folder in waptdev, or directly delete the setup.cpython-38.pyc file from the folder.
We'll look into adding a prompt to the console to delete the folder if it already exists, which will solve this problem.
Geoffroy
June 26, 2023 - 10:50
Okay, perfect.
Thanks for the feedback.
