[RESOLVED] Ghost packet on some computers
Sylvaner
Registration: June 28, 2023 - 2:17 PM
June 28, 2023 - 2:27 PM
I am writing to ask for your opinion because I have a very strange problem on 2 computers.
I created a group of packages which I called "base" due to a lack of imagination and I put various packages into it, including firefox.
Everything is going well for everyone else, it's wonderful. But for 2 positions, there's total confusion.
  • If I add the package group as a dependency, it installs everything except Firefox and gives me an error because the dependency is not resolved
  • If I only use Firefox, the package with the same identifier fails for the same reason
  • It does not appear in the self-service menu, neither as installed nor as not installed
Of course, I've done plenty of tests; the antivirus has the same rules as the others, the same permissions for everyone
  • Delete the console and station (multiple times)
  • Remove Firefox from the repositories and reinstall it
  • the WAPT-GET commands
    • wapt-get search XXXX-firefox: No result (this works with other packages)
    • wapt-get audit: I'm getting a 500 error on these two machines
    • wapt-get download: "Downloading packages" then it returns control
    • wapt-get install: It starts the task, but nothing happens and I get the following: Summary: Unavailable: XXXX-firefox and now I also get the error on my machine:
      Critical:
      === Unavailable packages ===
      XXXX-firefox [x64_fr_PROD]
    Does anyone have any ideas or leads on where to look because I'm stuck here?
    Thank you
June 28, 2023 - 3:32 PM
In the case of Firefox, it's often the language.
Is the package in your repository in French or English?
Is your computer in French or English?
The architecture can also play a role.
Sylvaner
June 28, 2023 - 3:47 PM
Wow, I'm impressed! :)
Indeed, both posts are in English, why? How? I don't know.
I'll test them and get back to you.
Thank you so much for this demonstration of talent. :)
