Update from 1.8.2 to WAPT 2.4
flo777
Registration: February 23, 2022 - 9:35 PM
August 6, 2023 - 6:19 PM
I was on WAPT 1.8.2.7393-75a5de09-debian-10-amd64, so a Debian 10 server. I'm looking to migrate to version 2.4.0.14080
I updated Debian to version 11, so PostgreSQL 13 (database migrated using pg_upgradecluster, everything went well...)
I then followed the upgrade procedure https://www.wapt.fr/en/doc/wapt-server-upgrade.html
During the post-installation step, I get:
root@host:~# sudo -u wapt /opt/wapt/bin/python -I /opt/wapt/waptserver/model.py upgrade-db -l info
initializing missing wapt tables without dropping data.
2023-08-06 17:21:57,559 INFO Connecting to waptdb explicitely. Count: 0
Unable to create tables, will try to upgrade step by step instead... : ProgrammingError('column "host_networking" does not exist\n')
2023-08-06 17:21:57,640 INFO Current DB: {'host': None, 'port': 5432, 'user': 'wapt', 'password': None} version: 1.9.0.4
2023-08-06 17:21:57,656 INFO Migrating from 1.9.0.4 to 1.9.0.12
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3144, in execute_sql
    cursor.execute(sql, params or ())
psycopg2.errors.UndefinedColumn: column t1.changelog does not exist
LINE 1: ...age", "t1"."icon_sha256sum", "t1"."is_available", "t1"."chan...
  File "/opt/wapt/waptserver/model.py", line 2784, in <module>
    init_db(False,server_config=conf)
  File "/opt/wapt/waptserver/model.py", line 2156, in init_db
    upgrade_db_structure(server_config=server_config)
  File "/opt/wapt/waptserver/model.py", line 2245, in upgrade_db_structure
    Packages.update_from_repo(r)
  File "/opt/wapt/waptserver/model.py", line 585, in update_from_repo
    (rec, _isnew) = cls.update_from_control(pe,is_available=True)
  File "/opt/wapt/waptserver/model.py", line 539, in update_from_control
    (rec, _isnew) = Packages.get_or_create(**key)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 6471, in get_or_create
    return query.get(), False
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 6884, in get
    return clone.execute(database)[0]
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 1907, in inner
    return method(self, database, *args, **kwargs)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 1978, in execute
    return self._execute(database)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 2150, in _execute
    cursor = database.execute(self)
  File "/opt/wapt/lib/python3.8/site-packages/playhouse/postgres_ext.py", line 490, in execute
    cursor = self.execute_sql(sql, params, commit=commit)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 3151, in execute_sql
    self.commit()
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 2917, in __exit__
    reraise(new_type, new_type(exc_value, *exc_args), traceback)
  File "/opt/wapt/lib/python3.8/site-packages/peewee.py", line 190, in reraise
    raise value.with_traceback(tb)
peewee.ProgrammingError: column t1.changelog does not exist
I also tried restoring a dump (pg_dumpall) of the old database (in case the upgrade to PostgreSQL 13 was a problem), but I get the same error
(Note: I reverted to WAPT 1.8.2 (without downgrading Debian, so still Debian 11) and everything works under this version (I did have to restore the database from a backup, the database migration due to the post-installation must have stopped halfway...)
Any ideas?
Sincerely
kguerineau
Registration: March 6, 2018 - 4:28 PM
August 8, 2023 - 12:00
We have just released a new version (2.4.0.14143) which contains a bug fix for migration from a 1.8.2 server https://www.wapt.fr/fr/doc/wapt-changelog.html
Have a good day.
flo777
August 8, 2023 - 7:32 PM
Thank you. I won't have time to test it right away (no drastic changes before the holidays!). I'll keep you posted in September.
Best regards,
Florian
