Insmonia package
Answer
jorico
Registration: August 11, 2022 - 4:42 PM
September 27, 2023 - 2:18 PM
Good morning
I tried to create a package for installing the Insomnia program (https://insomnia.rest/downloadThis can be installed via a portable application or with an application that installs in AppData (I was unable to complete the installation using this method)
I tried to base my work on the tis-bitwarden-portable package
Below is the setup.py file
app_bin = "Insomnia.Core-2023.5.8-portable.exe"
app_dir = makepath(programfiles32, "Insomnia")
app_bin_path = makepath(app_dir, app_bin)
processes_to_kill = ["Insomnia"]
    # Initializing variables
    package_version = control.version.split("-", 1)[0]
    bin_name = bin_name = glob.glob("Insomnia.Core-*.exe")[0]
    # Installing the package
    print("Installing: %s" % bin_name)
    if get_version_from_binary(app_bin_path) != package_version:
        killalltasks(processes_to_kill)
        if isdir(app_dir):
            remove_tree(app_dir)
        mkdirs(app_dir)
        print("Copying %s to %s " % (bin_name, app_bin_path))
        filecopyto(bin_name, app_bin_path)
        # remove_programs_menu_shortcut("Insomnia")
        # Adding this package to the "list-registry"
        register_windows_uninstall(control)  # control is a PackageEntry object corresponding to this package
        print("%s portable version is already installed in the correct version" % "Insomnia")
def session_setup():
    user_app_dir = makepath(application_data, "Insomnia")
    user_app_bin_path = makepath(user_app_dir, app_bin)
    # Installing the package in user env
    print("Installing: %s in user env" % "Insomnia")
    if get_version_from_binary(user_app_bin_path) != installed_softwares("Insomnia")[0]["version"]:
        if isdir(user_app_dir):
            remove_tree(user_app_dir)
        mkdirs(user_app_dir)
        print("Copying %s to %s " % (app_bin_path, user_app_bin_path))
        filecopyto(app_bin_path, user_app_bin_path)
        create_user_programs_menu_shortcut("Insomnia", user_app_bin_path)
        print("%s portable version in user env is already installed in the correct version" % "Insomnia")
    # Uninstalling the package
    if isdir(app_dir):
        unregister_uninstall("Insomnia")
However, during uninstallation, the application stored in AppData is not deleted...
And I have the impression that the session setup doesn't start after the application is installed; I have to force the session setup with `wapt-get session-setup -f ALL`
Can you help me improve my package?
Thank you all :D
WAPT Enterprise 2.5.5.15697
Server = Debian 11 Bullseye
Console = Windows Server 2019
Johan
Benoit
Registration: June 26, 2023 - 11:52
October 12, 2023 - 09:57
Unless I'm mistaken, it seems that your "session_setup()" function is not being called anywhere.
The following should be done in the install() function so that it is called at the end of the installation.
Furthermore, the session_setup() function should be positioned before the install() function so that it is read first.
        if isdir(app_dir):
        mkdirs(app_dir)
    session_setup()
Edit: I just realized my answer was irrelevant. My apologies.
Regards,
October 12, 2023 - 2:11 PM
jorico wrote: ↑Sep 27, 2023 - 2:18 PM And I have the impression that the session setup doesn't start after the application is installed; I have to force the session setup with `wapt-get session-setup -f ALL`
Actually, it's subtle...
After the installation of a package by the wapt service, the SERVICE Wapt will launch a session setup in all open sessions.
However, if you run a wapt-get install tis-insmonia, then the command line does not launch the session-setup.
So when you are in DEV mode, the session setup will not run.
I suppose that's your concern
Also, be careful during testing; you must increment the version of the control file and then run an installation, otherwise the session setup will do nothing. This is a common pitfall in WAPT training ;)
jorico
October 12, 2023 - 2:34 PM
Hello Simon,
Thanks for your reply. Indeed, there are a few subtleties. Below is the package as it works for me
Setup.py
app_bin = glob.glob("Insomnia.Core-*.exe")[0]
        if isdir(app_dir):
        mkdirs(app_dir)
    session_setup()
    if isdir(app_dir):
Control
package           : cam-insomnia
version           : 8.2.0-9
architecture      : all
section           : base
priority          : optional
categories        :
maintainer        : Johan RICOLLEAU
description       : Build better APIs faster and collaboratively with a dev-friendly interface, built-in automation, and an extensible plugin ecosystem.
depends           :
conflicts         :
maturity          : DEV
locale            :
target_os         : windows
min_wapt_version  :
sources           :
installed_size    :
impacted_process  :
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : Kong
keywords          :
licence           :
homepage          :
package_uuid      : 3682ac4f-05de-420d-b1ff-6e6f399c31d3
valid_from        :
valid_until       :
forced_install_on :
changelog         :
min_os_version    :
max_os_version    :
icon_sha256sum    :
signer            : ca-cert
signer_fingerprint: 42456f1e5e301d26521eeabdeb31734cf4c4c041fc7457e72108eae6a7868ac2
signature         : CXTKrvJIypc3UhJmEmSaMnEjbEe5wGavLw4rlfgK0uyVVvYkeesD7j6anRcdFNnkQCTPSeFoFqcd+6Ed36zsY8nIxcAt+BptModpMkc8NNSnTTPolmVawAO6PN2VeNz6pUs3QKC7h/plMalytb0f7eJMot8QfCzs2bs1AQwme5ColNPne2jMYADXYfbpkhGSTx0dYg7vTXr7rZnWkXU5O7c/DfF4b4/cns9NcH6dyazVTfndl1Oha/VChuJf06fNVaRuIzu7GqRBpj8z3p4ncf3B5AT+RGu4H2ixCAqj399VW12lM4tGB44ZjjUU6gM8kAgkUMbw2cofvIkfPSqEcQ==
signature_date    : 2023-10-12T14:23:08.439762
signed_attributes : package,version,architecture,section,priority,name,categories,maintainer,description,depends,conflicts,maturity,locale,target_os,min_wapt_version,sources,installed_size,impacted_process,description_fr,description_pl,description_de,description_es,description_pt,description_it,description_nl,description_ru,audit_schedule,editor,keywords,licence,homepage,package_uuid,valid_from,valid_until,forced_install_on,changelog,min_os_version,max_os_version,icon_sha256sum,signer,signer_fingerprint,signature_date,signed_attributes
I even tried an update_package
import json
def update_package():
    # Declaring local variables
    bin_contains = "Insomnia"
    result = False
    proxies = get_proxies()
    bin_search = ".exe"
    bin_name_sub = "Insomnia.Core.%s.exe"
    if not proxies:
    app_name = control.name
    git_repo = "Kong/insomnia"
    url_api = "https://api.github.com/repos/%s/releases/latest" % git_repo
    # Getting latest version information from official sources
    print("API used is: %s" % url_api)
    json_load = json.loads(wgets(url_api, proxies=proxies))
    for download in json_load["assets"]:
        if bin_search in download["name"]:
            url_dl = download["browser_download_url"]
            version = json_load["tag_name"].replace("core@", "")
            latest_bin = download["name"]
            break
    print("Latest %s version is: %s" % (app_name, version))
    print("Download URL is: %s" % url_dl)
    # Downloading latest binaries
    if not isfile(latest_bin):
        wget(url_dl, latest_bin, proxies=proxies)
        # Checking version from file
        version_from_file = get_version_from_binary(latest_bin, "FileVersion")
        if not version_from_file.startswith(version):
            # remove additional .0 at the end of the version from file
            ".".join(get_version_from_binary(latest_bin, "FileVersion").split(".")[:3])
            print("Changing version to the version number of the binary")
            version = version_from_file
            os.rename(latest_bin, bin_name_sub % version)
    if Version(version) > Version(control.get_software_version()):
        print("Software version updated (from: %s to: %s)" % (control.get_software_version(), Version(version)))
        result = True
    control.version = "%s-%s" % (Version(version), control.version.split("-", 1)[-1])
    # control.set_software_version(Version(version))
    # Deleting outdated binaries
    # Validating update-package-sources
    return result
Johan
jorico
October 12, 2023 - 2:55 PM
However, I have an audit error; I don't know what it is or how to resolve it
Johan
October 12, 2023 - 3:01 PM
app_bin should be in install at the time of auditing and session setup; the file no longer exists
which explains the error
jorico
October 12, 2023 - 4:23 PM
Thank you Simon
I corrected it, like this
app_bin = "Insomnia.Core.8.2.0.exe"
        if isdir(app_dir):
        mkdirs(app_dir)
    session_setup()
    if isdir(app_dir):
I no longer have audit errors, but I'm forced to hardcode the binary name... this will no longer work for the package update
Johan
October 12, 2023 - 5:46 PM
Hello Johan,
The binary name is available in the package at the time of installation, and in the c:\program files (x86)\Insomnia directory once the application is installed. You can move your app_bin variable between different functions by calling a
glob.glob('insomnia*.exe')
at the time of installation, and a
glob.glob(makepath(programfiles32,'insomnia','insomnia*.exe'))
at the time of session_setup and uninstall
Answer
