very simple question: is self-service available on Linux client machines? I haven't found any information on this in the documentation.
If so, how do I launch it?
Thank you in advance,
Dany Jeulin,
IT Department
, GIP RENATER
Self-service and Linux client workstation
- WAPT Expert
In theory, yes, even in "system" mode, but it depends on your system configuration.
In practice, it's mainly the waptserver-ldap mode that's implemented for our clients:
https://www.wapt.fr/fr/doc/wapt-self-se ... lf-service
sir_renater
- Registration: Sep 05, 2023 - 10:52
Thank you for your reply.
However, I have the impression that it is not installed by default with the agent, as it is for Linux/Mac machines. I cannot find the self-service application after installing the agent on my Linux machine.
- WAPT Expert
There's a separate executable file for placing the binaries:
tis-waptagent-gui
deb: https://wapt.tranquil.it/wapt/releases/ ... -amd64.deb
rpm: https://wapt.tranquil.it/wapt/releases/ ... x86_64.rpm
We put this separately because Linux servers without a graphical interface don't need it.
tis-waptagent-gui
sir_renater
Thank you for your reply, it works.
Would it be possible to make it a package directly available on the Wapt store?
- WAPT Expert
There's already an internal ticket; it should arrive soon
sir_renater
That's great news, thank you for your quick reply
- WAPT Expert
The package has been built:
https://luti.tranquil.it/listfolder/7ab ... 4cdf2cae2c
