[SOLVED] Error in DEF Uninstall
Geoffroy
Registration: June 28, 2022 - 3:34 PM
November 27, 2023 - 11:31
Hello team,
Server: WAPT Enterprise 2.4.0.14080 on Debian
Consoles: Windows 10 & 11
Park: Windows
I am currently experiencing a problem when running batch scripts.
with this order
   print("UNInstalling: Maya Services")
    run("START /B /WAIT cmd /c uninstall-autodesk-service.bat")
I don't have any errors on Wapt, but that doesn't do anything on the machine
With this order
    run("uninstall-autodesk-service.bat")
I'm getting an error: it's not recognized as an internal command by PyScripter
This is strange because I have other scripts for other programs that run very well on all machines.
What I understand is that I'm using these commands in Def Uninstall and I think it can no longer find the .bat files because the file is deleted at the end of the installation? Maybe I'm wrong.
Server: WAPT Enterprise 2.6.0.17226 on Debian 12;
Consoles: Windows 11
; Infrastructure: Windows
November 27, 2023 - 11:45 AM
Geoffroy wrote: Nov 27, 2023 - 11:31 run("START /B /WAIT cmd /c uninstall-autodesk-service.bat") I don't get any errors on Wapt, but it doesn't do anything on the machine
https://www.wapt.fr/fr/doc/wapt-create- ... installation
The `uninstall()` function cannot call files contained within the WAPT package. To call them, the files must have been copied to a local directory on the machine during package installation
During installation, the package is not retained to avoid increasing the machine's disk space. Therefore, in your installation file, you must copy uninstall-autodesk-service.bat somewhere so you can call it again during uninstallation
Or, more cleanly: directly write the contents of uninstall-autodesk-service.bat to the run function def uninstall
Geoffroy
November 27, 2023 - 12:34
sfonteneau wrote: Nov 27, 2023 - 11:45
That's what I thought.
Thank you very much, I'll test that and get back to you regarding the closure :D
Geoffroy
November 28, 2023 - 10:41
I can confirm that everything works correctly using Subprocess.
The script needed some adjustments, but it's all good now.
Thanks to the team.
