Log file cleanup
Answer
vince86
Registration: June 11, 2018 - 4:58 PM
December 19, 2023 - 3:12 PM
- Wapt Enterprise v2.4.0.14143.
- Windows Server 2016
My log files in C:\wapt\log:
nginx-access.log -> 2.21GB :o
nssm_waptserver.log -> 465MB
nssm_wapttasks.log -> 127MB
Can I delete them?
December 20, 2023 - 10:43
Hi Vincent,
yes, there is a default log rotation in waptserver for Linux, but this isn't the case for the Windows server. You can stop the services, delete the logs, and restart the services.
If you're comfortable with the Linux command line, I recommend migrating the server to Linux; nginx is much more efficient, and you'll be able to enable Kerberos authentication.
Best regards,
Answer
