[SOLVED] How to use multiple initial configurations
Answer
Benoit
Registration: June 26, 2023 - 11:52
November 29, 2023 - 11:30
I have WAPT Enterprise version 2.4.0.14143
on a Debian server, a
development PC, and a Windows 10 package.
My goal is to install:
- a WAPT agent with an initial configuration that automatically manages Windows updates on certain machines
- another agent with an initial configuration that does not automatically manage Windows updates on other machines.
How can I do this?
t.heroult
Registration: December 8, 2020 - 10:13 AM
December 20, 2023 - 9:38 AM
The simplest way is to deploy the agent uniformly using waptupgrade.
Next, different configurations need to be pushed depending on the workstations.
Take inspiration from the tis-wapt-conf-policy package.
Basically, for the WUA part, you'll have a configuration with
inifile_writestring(WAPT.config_filename, 'waptwua', 'enabled', 'True')
and one with
inifile_writestring(WAPT.config_filename, 'waptwua', 'enabled', 'False')
For the True version, it's up to you to determine the additional settings that suit you. Everything is in the online documentation.
Tom
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
Answer
