Stormshield Pack
kokoss22
Registration: January 2, 2024 - 10:23
January 2, 2024 - 10:26
I'm trying to create an uninstallation package for the Stormshield VPN Client SSL application. Our WAPT version (Enterprise version 2.4.0.14143)
The unique aspect of this VPN is that the application was deployed via Group Policy some time before WAPT was implemented. We have several versions of the Stormshield client in our network. The uninstallation script works correctly up to version 2.8.
I tried to set up a second uninstallation script for versions higher than 2.8, but I'm encountering a problem because the application was installed in the user's session (who doesn't have admin rights). Here is the script:
   pass
def session_setup():
for to_uninstall in installed_softwares(name=r"Stormshield SSL VPN Client"):
   if Version(to_uninstall["version"]) < Version('3.4') or force:
   print("Removing: %s (%s)" % (to_uninstall["name"], to_uninstall["version"]))
   killalltasks(control.impacted_process.split(","))
   run(r"MsiExec.exe /X{'clé'} /qn")
The script starts correctly, but a window appears asking for administrator rights.
I'm stuck on this step
Thank you for your help
January 2, 2024 - 10:40
Why launch the uninstallation in session_setup and not the install?
kokoss22
January 2, 2024 - 10:56
Thank you for your quick reply.
I tried to do it directly from def_install() but the script doesn't work.
January 2, 2024 - 11:15
A return code or something else?
kokoss22
January 2, 2024 - 1:19 PM
Yes, here is the feedback I received:
File "C:\\Program Files (x86)\\wapt\\common.py", line 4083, in install_wapt
  File "C:\\WINDOWS\\TEMP\\waptpyvay117\\setup.py", line 11, in install
  File "C:\\Program Files (x86)\\wapt\\common.py", line 3860, in run
  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2118, in run
    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))
waptutils.CalledProcessErrorOutput: Command \'MsiExec.exe /X{D76AA950-B963-4FF9-A389-01861A32876A} /qn\' returned non-zero exit status 1605.
Output:C\x00e\x00t\x00t\x00e\x00 \x00a\x00c\x00t\x00i\x00o\x00n\x00 \x00e\x00s\x00t\x00 \x00v\x00a\x00l\x00i\x00d\x00e\x00 \x00u\x00n\x00i\x00q\x00u\x00e\x00m\x00e\x00n\x00t\x00 \x00p\x00o\x00u\x00r\x00 \x00l\x00e\x00s\x00 \x00p\x00r\x00o\x00d\x00u\x00i\x00t\x00s\x00 \x00d\x00Ú\x00j\x00Ó\x00 \x00i\x00n\x00s\x00t\x00a\x00l\x00l\x00Ú\x00s\x00.\x00
\x00\r\x00
When I run msiexec from the workstation, it asks me for administrator rights to continue the uninstallation
January 2, 2024 - 2:13 PM
The error code is 1605
http://msdn.microsoft.com/fr-fr/library ... s.85).aspx
So ERROR_UNKNOWN_PRODUCT
In my opinion, the uninstallation process removes multiple entries at once, so you can correct your package by using `uninstall_key_exists`. If the key no longer exists, continue; this avoids uninstalling software that has already been uninstalled
        if not uninstall_key_exists(to_uninstall['key']):
            continue
            run(uninstall_cmd(to_uninstall['key']))
kokoss22
January 2, 2024 - 2:28 PM
I keep getting the same error
Installing paquet(=0-19)
Removing: Stormshield SSL VPN Client (3.2.3)
Erreur lors de l'installation de ['paquet']: erreurs dans les paquets [[PackageRequest(package='paquet',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.22621'),max_os_version=Version('10.0.22621')), PackageEntry('paquet','0-19'), 'Traceback (most recent call last):
 File "C:\\Program Files (x86)\\wapt\\common.py", line 5192, in install
 result = self.install_wapt(p.localpath,
 File "C:\\Program Files (x86)\\wapt\\common.py", line 4176, in install_wapt
 raise e
 File "C:\\WINDOWS\\TEMP\\waptai4rekuu\\setup.py", line 13, in install
waptutils.CalledProcessErrorOutput: Command [\'MsiExec.exe\', \'/X{D76AA950-B963-4FF9-A389-01861A32876A}\', \'/q\', \'/norestart\'] returned non-zero exit status 1605.
\x00\r\x00
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1910, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 716, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1288, in _run
January 2, 2024 - 5:51 PM
Microsoft correctly returns:
    1605 (0x645)
    Cette action est valide uniquement pour les produits déjà installés.
So, a strange scenario.
If you run the command:
Does it work on the machine if you go all the way?
kokoss22
January 2, 2024 - 7:59 PM
Yes,
I had already tested it beforehand; I have to enter admin credentials, but once that's done, the command works.
Thank you.
January 3, 2024 - 3:25 PM
You should try running the command in psexec:
psexec -s -i cmd
and in the command prompt, under system account, execute the command
Answer
