Hello Christophe,
as indicated in the upgrade documentation [1], the new WAPT upgrade package should normally be in forced installation mode and should be deployed to the workstations within 2 hours of the update (from the moment the agent is installed and configured on the workstation, so there is no difference with domain or workgroup workstations).
You can, of course, also update the GPO for the new workstations that will be deployed.
Regards,
[1] https://www.wapt.fr/en/doc/wapt-server- ... 2-x-to-2-5
[RESOLVED] Devices disconnected since update 2.5
- WAPT Expert
- WAPT Expert
I'm closing the thread.
Seen with Simon online. It was probably the post-conference that hadn't been restarted.kvnwsr wrote: ↑Feb 8, 2024 - 2:06 PM We don't have a reverse proxy.
I tried disabling the firewall, but it didn't change anything.
The connection is established via HTTPS, and certificate validation is not enabled on the clients.
Our configuration worked fine in version 2.4.
Can I revert to version 2.4, knowing that some clients have already upgraded to 2.5.3?
