[SOLVED] Problem updating new package
SaupinD
Registration: Oct 26, 2022 - 2:03 p.m.
February 19, 2024 - 2:37 PM
Server version: Debian 11
WAPT version: 2.5.4.15342
Console version: Windows 10 2.5.4.15342
I updated WAPT (from 2.4 to 2.5) and since then I can no longer update Tranquil-it packages from my repository.
The same issue occurs with manual package updates.
Any ideas?
February 20, 2024 - 1:56 PM
Hello Duane,
Could you please check if the "Directory of authorized external certificates" field is correctly filled in (see screenshot below).
Normally it should fill in automatically when you do an import from the internet... It references the Tranquil IT certificate of the store to validate that it is indeed a package that has been signed through LUTI at Tranquil IT.
I imagine you used the "Update from store" context menu. There's actually a workflow bug with this menu. We're going to modify it to redirect to the package import window. The recommended method is now to go to package import, then select
  • More recent than in my repository
  • Latest version only
  • Compatible with known machines
Leave the other options unchecked (architecture, languages, OS). This way, the console will calculate the necessary imports based on the machines you have in your console.
vcardon
February 20, 2024 - 8:21 PM
This is a pretty great feature because WAPT adapts to your usage and makes your life easier.
SaupinD
February 21, 2024 - 10:24
It works, thank you!
Duane SAUPIN
