Audit of the Firefox package
Answer
Mikael_S
Registration: Apr 25, 2023 - 11:57
April 17, 2024 - 2:04 PM
WAPT Enterprise, version 2.5.4.15342, Linux
I use an MSI package for Firefox deployment:
    # Declaring local variables
    # Installing the software
    print("Installing: Firefox Setup 124.0.2.msi")
    install_msi_if_needed('Firefox Setup 124.0.2.msi', key="Mozilla Firefox 124.0.2 (x64 fr)",min_version='124.0.2')
Browser updates are therefore done automatically at the machine level.
The problem is that the package audit fails as soon as Firefox is updated, because the uninstallation key has changed
t.heroult
Registration: December 8, 2020 - 10:13 AM
April 18, 2024 - 1:31 PM
Hello
, if you allow automatic updates, then you need to adapt the audit to take these changes into account.
In this case, you could test for the presence of the executable file rather than the uninstallation key, for example.
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
Mikael_S
April 19, 2024 - 2:49 PM
thank you for the suggestion. Perhaps not with the executable file, but I'll test the version first or possibly use a test file in the Firefox directory. I'll try it.
Answer
