tis-microsoft-teams-uwp package, uninstalling Teams Classic
Answer
Emmanuel64
Registration: February 23, 2024 - 09:37
March 12, 2024 - 10:24 PM
Good morning
I would like to disable the automatic startup of Teams (Work) by default
Since the appx installation format is different from "normal" packages, could you help me?
I was also thinking of uninstalling Teams Classic, do you think that's a good idea?
Would adding these lines be suitable?
for soft in installed_softwares('Teams'):
    if Version(soft['version']) < Version('24033.1005.2701.7380'):
        run(uninstall_cmd(soft['key']))
Thank you in advance for your help
WAPT Enterprise
Version 2.7.0.19593
Server OS: Debian Trixie
Administration machine OS: W11
Gaelds
Registration: Nov 22, 2015 - 08:37
April 22, 2024 - 2:37 PM
The code below seems to uninstall Teams classic correctly on my machines.
    for soft in installed_softwares('Teams Machine-Wide Installer'):
Emmanuel64
April 23, 2024 - 11:27
Thank you for your feedback.
Unfortunately, it didn't work on my Wapt dev machine.
Regards.
WAPT Enterprise
Version 2.7.0.19593
Answer
