[RESOLVED] tis-shotcut package
Gaelds
Registration: Nov 22, 2015 - 08:37
April 24, 2024 - 3:45 PM
I've been getting errors on dozens of machines since updating the Shotcut package to version 24.2.29:
  File "C:\wapt\common.py", line 4234, in install_wapt
  File "C:\WINDOWS\TEMP\waptdxx7y0ci\setup.py", line 12, in install
  File "C:\wapt\common.py", line 3990, in run
  File "C:\wapt\waptutils.py", line 2176, in run
waptutils.CalledProcessErrorOutput: Command '"C:\\Program Files\\Shotcut\\uninstall.exe" /S' returned non-zero exit status 1.
Output:Le chemin d'accès spécifié est introuvable.
The console indicates several versions of the software are installed:
2024-04-24 15_40_34-Window.jpg (24.19 KB) Viewed 8134 times
In reality, the directory "C:\Program Files\Shotcut\" no longer exists. By manually uninstalling the two lines in the control panel, the package eventually installs.
April 24, 2024 - 4:31 PM
Hello Gaël,
It's strange because the installation keys are still in the registry even though the referenced software is no longer there... There must have been some manual manipulation in the background...
You can add a try/except/pass block to ignore the error
try:
    run('%s /S' % soft["uninstall_string"])
except waptutils.CalledProcessErrorOutput:
    # supprimer la clef de registre correspondante et le répertoire correpodant
    pass
But then you'll have to manually delete the corresponding registry keys and check if the directory is still there to delete it if necessary.
Gaelds
April 25, 2024 - 11:01
No, nothing is done manually, but I think I was using a custom package for older versions of Shotcut (before the TIS package was available). I don't know why it didn't uninstall completely... For the problematic PCs, I created a temporary package that removed the registry keys.
April 25, 2024 - 11:33
Hi Gaël,
thanks for the feedback. Yes, it's good not to do anything manually when you have a WAPT client available. It could also be the installers themselves that are causing problems. In that case, you need to modify the `def uninstall()` function to add the necessary code to clean it up if needed.
Thanks for the feedback, I'm marking the topic as RESOLVED.
Best regards,
