[SOLVED] Remove the link between a package and the WAPT store
tux
Registration: Sep 05, 2023 - 09:44
May 13, 2024 - 2:03 PM
I imported a package from the store and then customized it.
How do I remove the link between my customized package and the store?
I don't want the package to be updated from the store so I don't lose the customizations.
Thank you in advance.
Wapt Enterprise Edition 2.6.1.17765
WAPTConsole Enterprise on Windows
WAPT Server on Debian 12
vcardon
May 13, 2024 - 7:15 PM
Hello Tux,
A useful practice to adopt is to create a configuration package (e.g., prefix-firefox-config) that has the package containing the binary (prefix-firefox) as a dependency (depends attribute).
This way, you benefit from the full security provided by Tranquil IT's CI/CD pipeline and you can modify your custom configurations independently of the store package.
tux
May 14, 2024 - 08:56
Hello Mr. CARDON,
I've already implemented your recommendation for several packages.
However, it doesn't apply to packages like tis-audit-local-admins.
How can I unlink the store from the prefix-audit-local-admins package that I've customized?
May 15, 2024 - 8:42 PM
tux wrote: May 14, 2024 - 08:56 How can I break the link between the store and the prefix-audit-local-admins package that I customized?
I don't understand the question; there's no link between the store and your Wapt repository
There is simply a duplication option in the "Import from Internet" tab if a version on our site is more recent than on yours.
Therefore, you should not add tis-audit-local-admins to your cart when duplicating from our repository.
tux
May 16, 2024 - 10:20
I want to prevent a colleague from accidentally updating the package from the store (i.e., it won't offer the update anymore).
If I understand correctly, the update offer is based on the name after the prefix? If I rename the package, will it no longer offer the update?
May 16, 2024 - 10:24
tux wrote: May 16, 2024 - 10:20 AM Hello,
If I understand correctly, the update offer is based on the name after the prefix? If I rename the package, it will no longer offer updates?
Exactly ;)
