[SOLVED] nginx problem
kbrozi
Registration: June 5, 2024 - 9:15 AM
June 5, 2024 - 10:26
I had to reinstall the WAPT server, but I'm encountering a problem when I try to install an agent: the nginx service is not found.
Can you help me?
Thank you.
Screenshot 2024-06-05 102540.png (11.74 KB) Viewed 7412 times
kbrozi
June 5, 2024 - 10:58
I just noticed that I can no longer connect to the WAPT server from the console
Screenshot 2024-06-05 105529.png (40.82 KB) Viewed 7409 times
June 5, 2024 - 11:26
Could you try running this?:
c:\wapt\waptpython.exe c:\wapt\waptserver\winsetup.py -ldebug install_nginx -cc:\wapt\conf\waptserver.ini
then restart the server
kbrozi
June 5, 2024 - 2:01 PM
After installing Nginx and restarting the WAPT service, I also restarted the VM, but it still doesn't work.
June 5, 2024 - 2:16 PM
Do you have anything in:
C:\Program Files (x86)\wapt\waptservice\nginx\conf?
or in
C:\wapt\waptservice\nginx\conf
kbrozi
June 5, 2024 - 2:26 PM
Here's what I have in the configuration:
kbrozi
June 6, 2024 - 08:46
In wapt service I don't have nginx:
Screenshot 2024-06-06 084455.png (111.82 KB) Viewed 7286 times
June 6, 2024 - 10:04
Contact our support team directly by phone.
Your nginx configuration appears to be incorrect even after restarting the service installation.
June 6, 2024 - 11:42
Seen over the phone.
It's normal that the Waptagent doesn't exist on a new installation. The procedure is therefore the same as for a fresh install.
However, the server was reinstalled, and the old HTTPS certificate was lost (and not backed up).
We therefore regenerated a correct Waptagent. It will then need to be redeployed across the network via Group Policy.
