[RESOLVED] Pyscript build upload disappeared since the update to 2.5.5
tux
Registration: Sep 05, 2023 - 09:44
June 5, 2024 - 11:14
we migrated our environment from version 2.5.2 to version 2.5.5.
Since the migration, the `build upload` command is no longer available in the PyScripter editor when editing a package.
How can I restore it?
Is PyScripter still the preferred editor for editing packages?
Thank you in advance.
Wapt Enterprise Edition 2.6.1.17765
WAPTConsole Enterprise on Windows
WAPT Server on Debian 12
June 5, 2024 - 11:25
The Build upload feature has been removed because importing is now done via the console for several reasons:
  • To avoid user context problems (the user profile, which is admin, is not necessarily the same as the console profile and therefore may not have the correct settings)
  • avoid having to retype the server password multiple times
  • avoid having to retype the private key password multiple times.
For these various reasons, build-upload has been removed from Python IDEs
Tip: If you drag and drop your package's working folder into the private repository, it will offer to import it.
tux
June 7, 2024 - 2:19 PM
thank you for the feedback and the tip.
