[SOLVED] Package import problem
scarf
Registration: Nov 22, 2023 - 3:27 p.m.
June 11, 2024 - 4:06 PM
Server WAPT: Debian 10 - Interface 2.5.4.15
Version: Enterprise
Here is the error I get after trying to import the Forticlient 7.2.4 package
2024-06-11 16_04_26-Importer des paquets.png (5.75 KB) Viewed 10599 times
This morning I called support to create an email address that could download this type of package.
Here are the repository settings:
CDT
2024-06-11 16_06_02-Importer des paquets.png (11.72 KB) Viewed 10599 times
June 12, 2024 - 09:46
Hi Romain,
there are packages containing licensed software for which you need to verify beforehand that you have both the software and the corresponding license before downloading the package (basically, Tranquil IT provides packaging assistance through the store package, but you already have the software and the corresponding license).
To verify that you have the software and the license, you need to go to the website and download the software. You will be asked for confirmation, and then you can download the package through the website or the console (the confirmation is saved for subsequent downloads; no need to re-validate once it's done).
Regards,
scarf
June 12, 2024 - 10:07
Thank you very much, it works.
Have a good day
regards.
June 12, 2024 - 2:17 PM
Hi again,
thanks Romain for your feedback :-) .
Don't hesitate to spread the word about WAPT; when you find good software, you should tell others ;-) !
