[RESOLVED] AdobeReader Package
Max.R
Registration: Apr 12, 2022 - 1:30 p.m.
June 17, 2024 - 3:33 PM
WAPT 2.4.0.14143 Enterprise
Server 2019
Hello
, I've noticed an issue when trying to update the Adobe Reader package with a target OS of Windows >=10.0 using the "Update from Store" function.
Instead of downloading the requested version, it loads the Adobe Reader version with a target OS of Windows >=6.1.
This isn't critical; I can simply download the correct package manually.
Regards
June 17, 2024 - 5:49 PM
Hi Maxime,
yes, there was a design flaw with that button...
We replaced it in version 2.5 with the "Import from Internet" window opening, with the "Compatible with known machines" checkbox. It should work better now. All that's left is to upgrade. :-)
Regards,
Max.R
June 18, 2024 - 11:22
Well, it seems I should look into version 2.5 then.
Thank you for your reply.
June 18, 2024 - 11:34
Thanks for your feedback, Maxime! :-)
Good upgrade!
