GLPI retrieval error
Answer
AnTho
Registration: Nov 21, 2023 - 1:49 p.m.
June 28, 2024 - 12:26
We have implemented the prod-glpi-plugin-export-to-glpi10 package to enable the upload of our IT inventory to GLPI.
GLPI version: 10.0.14
WAPT version: 2.5.5.15640 under Debian 12
The documentation allowed us to configure the package and obtain our first inventory reports on GLPI.
However, when accessing the WAPT console in the 'audit data' tab on some PCs, the following error is displayed:
GLPI audit error
GLPI audit error
2024-06-28 11_16_07-WAPTConsole Enterprise version 2.5.5.15640.png (5.19 KB) Viewed 8849 times
JSON format:
glpi.upload =
"hash": "failed",
"lastid": 7169009,
"output": " {\"status\":\"error\",\"message\":\"Unable to create item.\",\"expiration\":24}",
"status": "ERROR",
"synchro_date": "2024-06-28 10:24:29.242052"
Despite several searches and reconfigurations of the package, it was impossible to determine the fault.
If anyone has any ideas, I'd appreciate it because I'm a bit lost.
Good day
June 28, 2024 - 1:11 PM
there seems to be a lead here:
https://forum.glpi-project.org/viewtopi ... 48#p507148
So if I understand correctly, it's a uniqueness issue (serial number or something else depending on your import rules).
AnTho
July 1, 2024 - 12:14
Yes, indeed, when I went to GLPI and checked the "equipment import and linking rules," I found that some old rules were either inactive or misconfigured.
We need to clean things up.
Thank you and have a good day
Answer
