I wanted to install Dell COMMAND UPDATE on my network, but I'm having a dependency issue with .net 4.8.
In my private repository, I have all the Dell COMMAND UPDATE and dotnetfx packages.
The error message is: waptpackage.EWaptUnavailablePackage: Missing dependencies: uspn-dotnetfx4.8.
Could you please help me with this problem?
Ravichandran
ravichandran
- Registration: Sep 4, 2024 - 11:36
- Attachments
- 2024-09-23_10h42_05.png (25.47 KB) Viewed 4666 times
- WAPT Expert
Hello Ravichandran,
it seems there's a maximum version of Windows 10 for the package you listed in your internal repository. Your Windows 10 (or Windows 11) machine is probably running a version higher than that.
You can check the WAPT store; there's likely a newer version available.
Regards,
Regards,
ravichandran
Hello dcardon,
Thank you for your reply.
I checked the WAPT store. There is no new version that works on Windows 11.
Still waiting for a new version.
Best regards,
Ravichandran
Best regards,
Ravichandran
- WAPT Expert
Hello Ravichandran,
It seems the package has been fixed without a version increment... You can download the online version directly [1]; the min_os/max_os restriction flags are correct online. Otherwise, you can simply remove the package locally from your repository and re-import it.
I'm going to look into why the version hasn't been incremented.
[1] https://wapt.tranquil.it/store/en/detai ..._PROD.wapt
min_os_version : 10.0.18362
max_os_version : Denis
ravichandran
when I changed the control file with this information
: min_os_version: 10.0.18362
max_os_version:
dotnet 4.8, it installed correctly.
Thank you for your help
. Best regards,
Ravichandran
max_os_version:
. Best regards,
Ravichandran
