I'd just like to know if WAPT has already been deployed on Snapdragon architecture PCs. We're currently using WAPT 2.5.5.15691 and would like to explore the feasibility of upgrading our entire fleet (or at least part of it) to Snapdragon processors.
If not, is this planned for the future?
Thanks in advance.
[RESOLVED] WAPT PC Clients with Snapdragon Processor
- WAPT Expert
Hi Benoit,
there were some issues with the Lazarus/FreePascal compilation used in WAPT. But there have been very recent updates that seem to fix the problem [1]. We'll therefore be able to run internal tests again, and if they're successful, we should be able to have a WAPT version for Windows arm64 in the coming months.
See you soon,
[1] https://forum.lazarus.freepascal.org/in ... #msg537654
See you soon,
cg_heuliez
- Registration: Nov 13, 2024 - 08:23
Thanks for the information.
Have you made any progress with your tests?
- WAPT Expert
Hi Benoit,
we've made some fixes to the AMD64 agent to improve its compatibility with Rosetta on Windows ARM64.
Regarding native compilation on Windows ARM64, the necessary fixes haven't yet been implemented in the Free Pascal compiler.
Regards,
Regards,
cg_heuliez
Thanks for your reply!
Now, will this architecture really take off in the enterprise? I'm not so sure... Intel is trying to catch up with Lunar Lake...
- WAPT Expert
Hi again Benoit,
I found the Rosetta emulation layer quite impressive at first glance (it would take a month to form a more detailed opinion, but the first impression was really good
). So for simple business cases, I wouldn't be surprised if it could take off; time will tell!
Best regards,
Best regards,
